Reservation System
alpin3rocker
Reservation System
I "played" a little around with Aimeos the last Days, and i'm very impressed. Thank you for this cool System!
How is the best method to make a reservation system for holiday flats or some Equipement to rent?
Is it a mixed form of a Extension and configuration in Typo3 Setup and Plugins? Or Is there any ready solution available?
Thank you for answer
Re: Reservation System
We are very pleased that it excelled your expectationsalpin3rocker wrote:I "played" a little around with Aimeos the last Days, and i'm very impressed. Thank you for this cool System!
What do you like most?
For time based offers, I think there are two ways how to deal with that:alpin3rocker wrote: How is the best method to make a reservation system for holiday flats or some Equipement to rent?
- If the customer can freely choose any date or time range, an option would be to add a date selector as subpart in the catalog detail component and pass the date/dates to the basket as attribute. They should be stored as product attributes in the order.
- In most cases there will be a fixed date or time ranges and only one customer can rent real estates at the same time. Thus, a selection product with one sub-product for each time frame and a stock level of "1" would fit best in this case. The (sub-)products should be created by a script to minimize the manual efforts. This solution also has the advantage that you can use different prices for main seasons like Christmas.
Both solutions can be implemented using only the Aimeos code. An additional TYPO3 extension would be only necessary to host a custom Aimeos extension and it can be generated here: http://aimeos.org/developer/extensions/
We are not aware that besides the last solution (which works out of the box) there's already an open source extension available. There seemed to be at least one web site in the past that offered such functionality but we don't know how they implemented it.
One more suggestion: To make things easy for customers, it would be best to implement a date selector instead of a drop-down. Details about extending the basket subpart are available at http://aimeos.org/docs/Configuration/Co ... lated_partaimeos wrote: - In most cases there will be a fixed date or time ranges and only one customer can rent real estates at the same time. Thus, a selection product with one sub-product for each time frame and a stock level of "1" would fit best in this case. The (sub-)products should be created by a script to minimize the manual efforts. This solution also has the advantage that you can use different prices for main seasons like Christmas.
alpin3rocker
i generated a extension and pasted the needed template files with the file structure in
Resources/Extension/myextension/client/html/layouts/catalog/detail/
and installed the Extension in Typo3.
In the Setup of the Shop-Page i made a new type for the selection template:
in the file basket-selection-body-default.html i paste after <?php if( $layout === 'radio' ) : ?>:
in my "selection" Product assigned 4 Articles (day1, day2, day3, day4) with 2 attributes for each (duration and Startdate), the durations get a price
If the customer choose the duration the fitted field for the Startdate is showing and the user should pic a date.
Now the problem is, that i dont know if it is possible at that way or how i can pass the Value of the Startdate-input-field in to the Database and through the next order Steps.
Is there a possibility for a pdf invoice to the Customer or how would this be handled.
Thank you!
i like the Plugins with the configuration options with Typo-Script most.We are very pleased that it excelled your expectations
plugin.tx_aimeos.settings.client.html.catalog.detail.basket.selection.date = inputCode: Select all
<?php elseif( $layout === 'input' ) : ?>
<ul class="select-list" data-index="<?php echo $index++; ?>">
<?php foreach( $attrIds as $attrId => $position ) : ?>
<?php if( isset( $attributes[$attrId] ) ) : ?>
<li class="select-entry">
<input class="select-option" id="option-<?php echo $enc->attr( $attrId ); ?>" name="<?php echo $enc->attr( $this->formparam( array( 'b_prod', 0, 'attrvarid', $code ) ) ); ?>" type="radio" value="<?php echo $enc->attr( $attrId ); ?>" <?php echo ( isset( $attrIds[$id] ) ? 'checked="checked"' : '' ); ?> />
<!--<input class="select" id="option-<?php echo $enc->attr( $attrId ); ?>" name="<?php echo $enc->attr( $this->formparam( array( 'b_prod', 0, 'attrvarid', $code ) ) ); ?>" type="text" value="" />-->
<label class="select-label" for="option-<?php echo $enc->attr( $attrId ); ?>">
' . $this->media( $item, $contentUrl, array( 'class' => 'media-item' ) ) . '
<span><?php echo $enc->html( $attributes[$attrId]->getName() ); ?><input id="option-<?php echo $enc->attr( $attrId ); ?>" name="Verleihstart1" type="text" value=""></span><!--
--></label>
</li>
<?php endif; ?>
<?php endforeach; ?>
</ul>If the customer choose the duration the fitted field for the Startdate is showing and the user should pic a date.
Thank you!
Can you share a bit more information about your requirements? As far as I can see from your description, it wouldn't be possible to assign a stock level to your articles because in the end you only have a start date and a duration along with the product name and its price in your basket. Is that a problem in your case?alpin3rocker wrote: in my "selection" Product assigned 4 Articles (day1, day2, day3, day4) with 2 attributes for each (duration and Startdate), the durations get a price
The duration is still a drop-down ? This value is already passed to the basket because of the
name="<?php echo $enc->attr( $this->formparam( array( 'b_prod', 0, 'attrvarid', $code ) ) ); ?>"If the start date is a custom input field with arbitrary values, we have to extend the addProduct() method of the basket controller to allow such values and the basket standard HTML client to pass the data to the basket controller. The start date can be a single attribute of the selection product itself because we only need it displayed once. For the form parameter, the same name structure is used:
name="<?php echo $enc->attr( $this->formparam( array( 'b_prod', 0, 'attrcustid', $code ) ) ); ?>"Currently, the order is displayed on the confirmation page where it could be printed easily. Alternatively, you could add a section that creates a PDF file for the order on that page too or attach a generated PDF file to the e-mail.alpin3rocker wrote: Is there a possibility for a pdf invoice to the Customer or how would this be handled.
We've implemented custom attributes with arbitrary values in the latest core. That should be what you need get your reservation system up and running. The current demo data deals with texts but you can store dates as text as well.alpin3rocker wrote: Now the problem is, that i dont know if it is possible at that way or how i can pass the Value of the Startdate-input-field in to the Database and through the next order Steps.
- basket-detail.png (13.63 KiB) Viewed 43268 times
- demo-product.png (13.71 KiB) Viewed 43268 times
- admin-interface.png (21.33 KiB) Viewed 43268 times
alpin3rocker
this looks good. Thank you a lot!
I tried to update/replace only the arcavias-core in the installed Aimeos extension Typo3 7.1.0.
After that i pressed the green update circle-button of Aimeos in Ext-Manager.
But the Frontend looks like in the Attachment. What is wrong? Or How should i do the update the right way?
Thank you!
Thank you!
- screen1.jpg (35.86 KiB) Viewed 43246 times
alpin3rocker
from the Log, maybe it is helpful for you...
Core: Error handler (FE): PHP Catchable Fatal Error: Argument 2 passed to MW_View_Helper_Partial_Default::__construct() must implement interface MW_Config_Interface, none given, called in /user/www.domain.at/typo71/typo3conf/ext/aime ... efault.php on line 57 and defined in /user/www.domain.at/typo71/typo3conf/ext/aime ... efault.php line 32
You need the current TYPO3 code and the latest core because both need to play together.alpin3rocker wrote: I tried to update/replace only the arcavias-core in the installed Aimeos extension Typo3 7.1.0.
There's now some documentation about the parameters needed to put an article into the basket:
http://aimeos.org/docs/Configuration/Co ... Parameters
This should help you if you still need to change the basket subpart of the catalog detail component.
