As per Indian regulations -Stripe payment
Mayank
Post by Mayank » 13 Oct 2020, 13:00
php version: 7.2
aimeos version: ~2019.10
As per Indian regulations, export transactions require a customer name and address. More info here: https://stripe.com/docs/india-exports
I am using stripe payment options, but I am getting the above message. I added customer address and details, but it's giving me the same error.
Also, In backend. I am already sending https://prnt.sc/uygz0d
option
address: yes
stripe screenshot:
https://prnt.sc/uyh0l3
please let me know, what I am missing here.
Re: As per Indian regulations -Stripe payment
Post by aimeos » 14 Oct 2020, 06:50
Can you please check here why the address data is not available in your case?
https://github.com/aimeoscom/ai-payment ... #L701-L703
Mayank
Post by Mayank » 14 Oct 2020, 08:20
getting address here, https://prnt.sc/uyzqjh
also here https://prnt.sc/uyzroi
but in
$response = $this->sendRequest($order, $data);
but I am getting this
https://prnt.sc/uyzsk7
also, in stripe.. no customer is attached to it.
https://prnt.sc/uyzt9p
it's adding customer without any name or billing address
https://prnt.sc/uyzyc5
Post by aimeos » 14 Oct 2020, 08:25
Then, it seems to be a problem in the Omnipay Stripe driver that the address data is not passed to Stripe:
https://github.com/thephpleague/omnipay-stripe
Mayank
Post by Mayank » 14 Oct 2020, 08:35
I am using an old version
Aimeos (aimeos.org), 2015-2018
Will it be the issue?
Post by aimeos » 14 Oct 2020, 09:02
Even in Aimeos 2015.10 it was already possible to add the address data, so I don't think it's a problem of Aimeos. Maybe the Stripe version is too old and doesn't support this feature in your used version.
Nevertheless, you should upgrade to Aimeos 2020.10 because 2015.10 isn't supported since years and there may be but or security issues inlcuded.
Mayank
Post by Mayank » 14 Oct 2020, 09:30
yeah, It's not the version issue, now I am using the latest version but I am facing the same issue.
