Change currency to integer values
earosb
Post by earosb » 10 Aug 2016, 16:30
Hi there,
I can't figure out how to change a currency to integer values, is a bit strange to see the prices with decimals for my.
Thanks for any help!
Re: Change currency to integer values
Post by aimeos » 10 Aug 2016, 21:07
Which currency are you using?
At the moment, you can change the decimal and thousands separator but not the number of decimal digits. We will make that configurable in the next version.
earosb
Post by earosb » 11 Aug 2016, 15:39
aimeos wrote:Which currency are you using?
We are using Chilean peso and a virtual currency that we invented.
The next version will be released in October?
Post by aimeos » 15 Aug 2016, 20:51
Yes and in the meantime, you can use dev-master. There won't be any breaking changes till October.
