Correct way to integrated user login
FAlberto
Post by FAlberto » 15 Mar 2019, 14:25
Hi, I added the aimeos package to my project in Slim.
How I can addapt my login system and user sessions with the aimeos package?
I don't know well how I can manipulate the code to unify my app with the aimeos package.
slim/slim: 3.0,
aimeos/aimeos-slim: ~2018.10
Thanks in advance.
Re: Correct way to integrated user login
Post by aimeos » 16 Mar 2019, 11:20
You have to implement a customer manager that can store the required data and offers the same semantics as the the Laravel customer manager for example:
https://github.com/aimeos/ai-laravel/tr ... er/Manager
If you don't use a standard PHP session, you must implement an adapter for your session handling like this:
https://github.com/aimeos/aimeos-core/b ... on/PHP.php
