crud
АзатМхитарян
crud
Post by АзатМхитарян » 28 Feb 2020, 12:04
How to make crud in aimeos?
АзатМхитарян
Re: crud
Post by АзатМхитарян » 28 Feb 2020, 12:48
My environment is
Php 7.2
Ubuntu 19.04
Aimeos 2019.10
SaurabhSharma
Re: crud
Post by SaurabhSharma » 28 Feb 2020, 13:09
АзатМхитарян
Re: crud
Post by АзатМхитарян » 28 Feb 2020, 13:21
thank you for your reply, do you make a crud in aimeos?
can you give me a guide how to create crude for slider?
Re: crud
Post by aimeos » 28 Feb 2020, 15:17
You mean "create", "retrieve", "update" and "delete" data (CRUD)?
The low level API (managers) use:
- createItem() -> create but not in database, only the object in memory
- getItem() / findItem() / searchItems() -> retrieve
- saveItem() / saveItems() -> insert or update depending if an ID is available
- deleteitem() / deleteItems() -> delete
The possibilities are documented here:
https://aimeos.org/docs/Developers#Managers_and_items
