Is it Resonse::view or will it be Response::view ?
auvee.aslam
Post by auvee.aslam » 28 Apr 2019, 10:40
In the aimeos.org/laravel-ecommerce-package/ , it is said that coding standard in aimeos is like,
Resonse::view( 'shop.catalog.list', [
'listbody' => Shop::get( 'catalog/lists' )->getBody(),
'listhead' => Shop::get( 'catalog/lists' )->getHeader()
But I think it should be strated with Response::view( 'shop.catalog.list', [ ....... If my thought is right then it should be corrected from that page as aimeos is a good solution and becoming a great thing. Thank you.
Re: Is it Resonse::view or will it be Response::view ?
Post by aimeos » 29 Apr 2019, 09:07
Thank you for your hint! It has been fixed now
