Rest Apis for mobile apps
traiyani75
Re: Rest Apis for mobile apps
Post by traiyani75 » 15 Nov 2019, 10:17
Yes, Use this api for references
http://ebdaa-ecommerce-dev.mzadqatar.co ... duct?id=12
in this, what will be includes for varients, characteristics, properties, related products, similar products.
Post by aimeos » 16 Nov 2019, 16:06
A full include for products would be:
include=attribute,media,price,product,product/property,text
traiyani75
Post by traiyani75 » 19 Nov 2019, 09:43
Hello guys,
We have a parsed response of category. Now we are on another phase to parse product details response.
This is url for product details
http://ebdaa-ecommerce-dev.mzadqatar.co ... perty,text
Is there any idea way to parse it, and display data into mobile screen. In the above API, We get data of product into data object. Then it has relationships, inside it we have other product data which are related to the main requested one. Now that suggested products have relationships too.
How do we parse all things, and map it's attributed perfectly?
regards
Post by aimeos » 19 Nov 2019, 22:44
You should parse all responses the same way as they are very similar. As products can contain products, you need to implement a recursive method for parsing. Similarly, we use a recursive method for generating the response on the server.
