Temporary order limit reached
Travin
Post by Travin » 13 Jan 2018, 12:57
I have error at the checkout page: Temporary order limit reached. Could i change the limit?
Re: Temporary order limit reached
Post by aimeos » 13 Jan 2018, 13:00
Travin
Post by Travin » 13 Jan 2018, 13:07
Thanks!
gurubroz
Post by gurubroz » 15 Dec 2022, 07:45
Hi there,
I have TYPO3 v11.5.20 and Aimeos v22.10.3
I have tried https://aimeos.org/docs/latest/config/c ... imit-count
For this error https://i.imgur.com/OUjaa2j.png
I have tried the solution in my Template TypoScript part like this:
controller.frontend.basket.limit-count = 0
controller.frontend.basket.limit-seconds = 31536000
But still, I faced the same error. So, is there anything wrong with the above configuration?
Post by aimeos » 16 Dec 2022, 08:56
Setting it to 0 doesn't allow you to place orders any more. Instead, you should use a higher value like 10, 25 or more (for testing only).
nowrap
Post by nowrap » 26 May 2023, 20:06
is it possible to set limit-count and limit-seconds for a specified user individual?
Regards
nowrap
Post by aimeos » 27 May 2023, 08:20
Actually, the config values are specific for each user, not for all users at once.
nowrap
Post by nowrap » 27 May 2023, 20:20
Thanks for your reply. My idea was to disable the limit for some users and keep the default values for everyone else.
Post by aimeos » 28 May 2023, 22:53
No, that's not possible.
