Help with Json API - Filtering the product list
Re: Help with Json API - Filtering the product list
Post by aimeos » 20 Mar 2018, 16:31
kisese
Post by kisese » 15 Jul 2018, 13:45
HI,
A little help whenever i run the filter
http://localhost:8000/jsonapi/product?filter[=~][product.type]=select
I get all results instead of the filtered result. Also the example in the documentation
http://localhost:8000/jsonapi/product?filter[>][product.type.code]=select
for getting products of type "select" does not return correct data.
Kindly assist :)
Aimeos version: 2017.10
PHP version: 7.1
Package: Laravel
Environment: Windows
Post by aimeos » 17 Jul 2018, 22:30
kisese wrote: I get all results instead of the filtered result:
If you put that into the address line of you browser, the "=~" will be interpreted as "filter[", "=" and "~][product..." which isn't passed to the server correctly. The second problem is that "product.type" is a added to the result for simplification but only "product.type.code" remains a valid search key.
kisese wrote: Getting products of type "select" does not return correct data:
This filter does return all products whose type is lexicographically beyond "select". In the latest Aimeos version it will return products of type "voucher", in your version it will return nothing.
The correct URL for pasting into the browser would be:
http://localhost:8000/jsonapi/product?filter%5B%3D%3D%5D%5Bproduct.type.code%5D=select
like stated in the docs. If you pass the "{"filter": {"==": {"product.type.code":"select"}}}" JS object to e.g. to the jQuery $.ajax() method, it will get encoded automatically.
kisese
Post by kisese » 18 Jul 2018, 10:08
Thank you very much, I get it now. and thanks for the wonderful product. :) :)
