Feature: Suppliers (extra fields / translations)
Yvler
Re: Feature: Suppliers (extra fields / translations)
Post by Yvler » 24 Aug 2015, 15:10
I changed the supplier default.php manager, but still not working..
And I've committed this to core again
Post by aimeos » 24 Aug 2015, 15:13
Yvler wrote:I changed the supplier default.php manager, but still not working..
Travis reported an error: https://travis-ci.org/aimeos/aimeos-core/jobs/76996159
The $map variable isn't defined. You should have a look into the customer manager for reference.
Yvler
Post by Yvler » 25 Aug 2015, 09:11
After a lot of debugging, found the problem. I forgot to update the Supplier Item default interface with the listitem & refitem arrays :)
added these changes to the git
also updated the searchitems function in core again to fix the Travis error & use the builditems functions.
Weird enough, I thought I fixed these things last week.. maybe forgot to commit :)
Post by aimeos » 25 Aug 2015, 09:22
Yvler wrote:After a lot of debugging, found the problem. I forgot to update the Supplier Item default interface with the listitem & refitem arrays :)
You forgot to commit at least the first part again ;-)
https://github.com/aimeos/aimeos-core/pull/29/files
