Creating a subcomponent
Re: Creating a subcomponent
Post by aimeos » 19 Aug 2015, 16:07
Luke wrote:are you able to give me an example directory structure and class name / filename
You don't need to create a new class for removing a component.
If you are using e.g. Laravel, add this to your "./config/shop.php" file:
'client' => array(
    'html' => array(
        'catalog' => array(
            'detail' => array(
                'default' => array(
                    'subparts' => array('image', 'basic', 'actions', 'basket', 'bundle', 'additional', 'suggest', 'bought', 'seen'),
As the "client/html/catalog/detail" arrays are already existing, you only need to add the "default" and "subparts" lines including the brackets there. By reordering the list in "subparts", you can also move the parts to other positions :-)
Luke
Post by Luke » 19 Aug 2015, 16:10
perfect thanks :)
Bananamoon
Post by Bananamoon » 20 Aug 2015, 13:04
So what if you do have to change some params in _setViewParams? You do have to change the name of your class, right?
Like this as Luke defined?
class Client_Html_Catalog_RotexDetail_Default
   extends Client_Html_Catalog_Detail_Default
And how does the default subcomponent will use this? Do you need to add your own subcomponent in the shop.php config file?
Just so my brain understands lol :D
Post by aimeos » 20 Aug 2015, 13:33
Bananamoon wrote:So what if you do have to change some params in _setViewParams? You do have to change the name of your class, right?
The best way would be to create a decorator, e.g. "Client_Html_Common_Decorator_Rotex" and add the required values in the getBody() and getHeader() methods. This is the preferable way over subclassing because you can add several independent decorators to the class via configuration:
class Client_Html_Common_Decorator_Rotex extends Client_Html_Common_Decorator_Abstract
  public function getBody(...)
    $view = $this->setView( $this->_setViewParams( $this->getView() ) );
    return $this->_getClient()->getBody();
  protected function _setViewParams( $view, ... )
Add this and other decorators to the catalog detail client only with https://aimeos.org/docs/Configuration/C ... tors/local
In very special cases when only subclassing is an option, than you should create a class named like this:
class Client_Html_Catalog_Detail_Rotex
Bananamoon wrote:And how does the default subcomponent will use this? Do you need to add your own subcomponent in the shop.php config file?
To use the alternative "Rotex" implementation, you have to configure it's name in the config file. For the catalog detail class itself it's https://aimeos.org/docs/Configuration/C ... etail/name
Bananamoon
Post by Bananamoon » 20 Aug 2015, 13:42
Alright! Makes sense :-) Does this also count for, say, Basket?
So you add a decorator in "client/html/basket/decorators/local"?
Thanks for your help, really appreciate it :-)
Post by aimeos » 20 Aug 2015, 14:44
Bananamoon wrote: Alright! Makes sense :-) Does this also count for, say, Basket?
Like for every code in Aimeos: If it works for one thing, it works for all others which are similar as well ;-)
For the standard basket, the configuration would be: https://aimeos.org/docs/Configuration/C ... tors/local
Simply wait for the minor release of the core tomorrow. Then everything will work as described :-)
Post by aimeos » 21 Aug 2015, 13:33
Soo, the new Aimeos core release is out (2015.07.4 for the Aimeos Laravel and Symfony 1.1 packages) and we've added an article about decorators for HTML clients as well: https://aimeos.org/docs/Developers/Html ... components
Have fun! :-)
Bananamoon
Post by Bananamoon » 03 Sep 2015, 07:32
aimeos wrote:Soo, the new Aimeos core release is out (2015.07.4 for the Aimeos Laravel and Symfony 1.1 packages) and we've added an article about decorators for HTML clients as well: https://aimeos.org/docs/Developers/Html ... components
Have fun! :-)
Hello! First of all, thanks for the update!
I've been trying to actually implement this, for the mini basket but fail to complete it so far.
Here's what I got:
class Client_Html_Common_Decorator_Optiphar
    implements Client_Html_Common_Decorator_Interface
    protected function _setViewParams( MW_View_Interface $view, array &$tags = array(), &$expire = null )
This decorator is stored in: ai-project/client/html/basket/mini/decorators/local/Medecorator.php
In the shop config file I have this decorator declared in:
client/html/basket/mini/decorators/global/mydecorator
I get the following error:
Client_Html_Exception in Abstract.php line 62:
Class "Client_Html_Common_Decorator_Optiphar" not found
I've tried to change my classname, tried to change the directory where it is stored, but I really have no clue what is going wrong?
Thanks for the help! :)
Post by aimeos » 03 Sep 2015, 08:25
Bananamoon wrote: I've been trying to actually implement this, for the mini basket but fail to complete it so far.
Here's what I got:
In the shop config file I have this decorator declared in: client/html/basket/mini/decorators/global/mydecorator
For a local decorator, your file name is wrong and it's stored in the wrong directory.
It needs to be named "Client_Html_Basket_Mini_Decorator_Optiphar" and stored in "ai-project/client/html/src/Client/Html/Basket/Mini/Decorator/Optiphar.php". The configuration must be
client/html/basket/mini/decorators/local = array( 'Optiphar' )
Bananamoon
Post by Bananamoon » 03 Sep 2015, 09:31
Here's what I got:
Yay Error gone! Altho I have no clue what to do now, since I thought that this file would extend/overwrite this file:
class Client_Html_Basket_Mini_Main_Default
	extends Client_Html_Abstract
I'm at loss, I guess I made the wrong extension or something? :P
My main purpose is to show the products I put in my basket, instead of just the amount of products. I would like to add that to the cache so it loads quicker, so I figured I have to extend/overwrite above file and rewrite the _setViewParams.
Thanks again for your help! You're awesome! :)
