Forum rules: Always add your Aimeos and PHP version as well as your environment (Linux/Mac/Win)
#3408 by wenotine
19 Sep 2016, 15:21
Thank you again for your last help, now we are working on the language file.
I saw your documentation and checked Transifex.
I found the .po languge files, but if I change any words on the file, nothing happening on the site.
How can I add the .po files or how can I generate the language from the .po file?
I saw that it uses the mo.php, but dont understand what to do...
Thank you!
#3410 by aimeos
19 Sep 2016, 15:37
Translate the strings at Transifex. We will update dev-master and generate the necessary files afterwards.
#3437 by wenotine
26 Sep 2016, 08:24
Thank you for your help again.
We finished the translation to Hungarian(hu) language on transiflex, please install the language file, and let me know what I have to do to reach it.
Thank you!
#3440 by aimeos
26 Sep 2016, 09:59
Great! Thank you very much! :-)
We've updated the dev-master branch so you will get the new translations if you change your composer.json to use dev-master for the Aimeos packages and do a "composer update" afterwards.
#3461 by nora1984antal
28 Sep 2016, 12:53
We've already seen the Hungarian(hu) translation after the composer update. Thank you. We've updated some text in the translation on Transifex.
Please, update them in the dev-master.
thank you
#3465 by aimeos
29 Sep 2016, 07:52
Thank you for the translations. They have been updated in dev-master.
#3471 by nora1984antal
30 Sep 2016, 08:18
we've found another mistakes so we've updated the translation again. Please, update them in the dev-master.
Thank you
#3533 by nora1984antal
18 Oct 2016, 07:37
Hello aimeos,
there are a lot of changes in the hungarian translation, and we don't see them in the last update. We need the corretc translations so please update them. And we would like to know that the aimeos version 2016.10 consists the last translations or only the dev version does.
Thank you
#3547 by aimeos
19 Oct 2016, 16:53
The translations are now up to date in the dev-master and 2016.10 branch. They will be available via composer with the next minor releases.
