unpack(): Type V: not enough input, need 4, have 0
SandipDas
Post by SandipDas » 06 Oct 2020, 13:19
when I click on admin part and click the order tab it gets error.
but if i switch over from english to detch or any other language it works fine, english version doesnot work,please help
SandipDas
Re: [solved] new extension not working
Post by SandipDas » 06 Oct 2020, 13:31
ext/ai-gettext/lib/custom/src/MW/Translation/File/Mo.php line no 189
when i convert english it gets error but it works fine in local
Re: unpack(): Type V: not enough input, need 4, have 0
Post by aimeos » 06 Oct 2020, 13:36
The binary Gettext files (.../i18n/{en,de,ar,etc}) seem to be corrupt.
Please make sure that the are not changed when uploading them to your server.
SandipDas
Post by SandipDas » 06 Oct 2020, 15:02
ok if i upload files within gettext then it will work, it is an error only for english.so which one i will upload this files, can you say the path "ext/ai-admin-jqadm/admin/i18n" actually locally it works fine
SandipDas
Post by SandipDas » 06 Oct 2020, 15:14
anyone can help me why i am getting error it is only for english, and which file will i upload ? can you say me the specific path just because same folder set up in my local it works fine, so i will replace those files
Post by aimeos » 06 Oct 2020, 15:30
"ext/ai-admin-jqadm/admin/i18n" contains all translations for the admin interface including the English one.
SandipDas
Post by SandipDas » 06 Oct 2020, 15:43
ok i understood but what will i do now? will i replace en.po from my local to server. But i didnot see any en.po file within this path ext/ai-admin-jqadm/admin/i18n but i saw en.po files within "ext/ai-client-html/client/i18n" or "/ext/ai-admin-jqadm/admin/i18n" or " /ext/ai-controller-frontend/controller/frontend/i18n" and so on. so what should i do ? i will replace files or i will upload files once again
SandipDas
Post by SandipDas » 07 Oct 2020, 07:47
What should i do ?
Post by aimeos » 07 Oct 2020, 11:08
Upload the files once again to your server.
You can zip all files and unzip them on the server as this provides more data integrity.
