Catalog filter
Harpal Singh
Catalog filter
Post by Harpal Singh » 22 Oct 2019, 10:51
Is it possible to write my own routes/urls for search or other filters.
Rather than
../list?f_attrid[0]=332&f_name=abc&f_catid=279
I want to create a URL like
list?company_id=332&cat_name=lanyards&cat_id=279
Re: Catalog filter pretty urls
Post by aimeos » 23 Oct 2019, 08:20
You can adapt the Laravel routes:
https://aimeos.org/docs/Laravel/Custom_routes
But to change the parameter names (e.g. from f_catid to cat_id) you would need to change the templates and the HTML client classes that process the parameters.
Harpal Singh
Re: Catalog filter
Post by Harpal Singh » 29 Oct 2019, 10:22
In the above URL I want to change query string from array to string because URL does not look pretty with array-like: `f_attrid[0]=332`.
Re: Catalog filter
Post by aimeos » 30 Oct 2019, 07:16
You can try to change the Laravel router behavior in some way to transform array parameters differently when generating and resolving URLs.
