Forum rules: Always add your Laravel, Aimeos and PHP version as well as your environment (Linux/Mac/Win)
#5929 by mohal_04
02 Apr 2018, 10:50
Laravel: 5.6
Aimeos: 2017.x
PHP: 7.x
Environment: Linux
I have created an extension. This extension gives an extra field on Product form. I have spent 2 days to figure out the customization that are required to save this extra field in DB. So, after writing all code I am still unable to save it in DB. So, I thought of writing a Unit Test for this.
But now this Unit Test is giving me a new error, which I don't know how to fix. I have been following all steps from this official link: https://aimeos.org/docs/Developers/Library/Extend_managers_items
And when I tried the unit test, I get this error:
BUILD FAILED
C:\wamp\www\aimeos-core\build.xml:12:114: Task exited with code 255
This errors shows up when I execute this command in terminal:
Code: Select all./vendor/bin/phing setup
Can anyone help me with this?
Thanks!
