What is the best way to create blog within Aimeos?
D-Cell
Post by D-Cell » 21 Jan 2019, 17:40
Hello! I`m thinking about to create a blog for my Aimeos website, so i would like to ask - which way is the best?
Should i create a simple CRUD as i usually do with laravel and extend my views with aimeos views? If so, than how to integrate such blog into Aimeos admin panel?
Or, may be, there is some other way?
Thank you! ;)
D-Cell
Re: What is the best way to create blog within Aimeos?
Post by D-Cell » 22 Jan 2019, 08:14
Sorry! I forgot to provide info about my environment.
I work with Linux Fedora 28, PHP 7.2.13, Mariadb 10.2.19, Nginx. Laravel 5.7.18 and Aimeos 2018.10.3
Post by aimeos » 22 Jan 2019, 13:11
The requirements of a blog are very different from a shop so Aimeos won't help you much. You should check if there's any Laravel blog package that fulfills your needs or your take a look at that one: https://cms.grafite.ca/
D-Cell
Post by D-Cell » 22 Jan 2019, 14:00
aimeos wrote:The requirements of a blog are very different from a shop so Aimeos won't help you much. You should check if there's any Laravel blog package that fulfills your needs or your take a look at that one: https://cms.grafite.ca/
Hello! Thank you for reply! Now i`m writing my own simple blog based on simple Laravel CRUD - just one model, resource controller and view files for actions. The only thing i can`t figure is how to extend the view blade files of my blog with Aimeos layout. In other words - i need my "addpost" and "edit post" pages to be part of Aimeos admin panel with Aimeos header, footer and menu.
Could you be so kind to give me some advice about it?
Thank you.
Post by aimeos » 23 Jan 2019, 14:49
For the frontend, you can use the app.blade.php file you've created for Aimeos. Either extend from that file or assign the rendered blog to the view property named "content".
For the backend, you can add a new Aimeos admin client that implements create/search/save methods like this one:
https://github.com/aimeos/ai-admin-jqad ... QAdm/Group
You can use the Laravel facades and methods to work with e.g. Eloquent models.
Then, you have to add it to the navigation bar (insert the content in your ./config/shop.php into the "admin" section with "jqadm" => ["navbar" => ...] sub-array):
https://github.com/aimeos/ai-admin-jqad ... navbar.php
and configure permissions in your ./config/shop.php with:
'admin' => [
    'jqadm' => [
        'resource' => [
            'blog' => [ // that's the name of your client, e.g. Admin\JQAdm\Blog
                'groups' => ['editor', 'admin', 'super'],
D-Cell
Post by D-Cell » 23 Jan 2019, 17:51
aimeos wrote:For the frontend, you can use the app.blade.php file you've created for Aimeos. Either extend from that file or assign the rendered blog to the view property named "content".
'admin' => [
    'jqadm' => [
        'resource' => [
Thank you! Thanks a lot! This is exactly what i was trying to find out!
