How to implement a down payment / deposit option
Re: How to implement a down payment / deposit option
Thanks again,
sorry for the confusion, I thought that I had to update the basket, not only return the newly calculated price, now it seems to work.
Best regards,
Ralf
Best regards,
Ralf
justynpride
Wondering if this resolved your problem? I'm looking at having a similar feature and wondered if this fully resolved for you, or if you needed to make any other changes? If so is it possible to share any code please?
I have a similar situation, only the deposit rate is customizable, it can be 40% 50%, 60%, etc. I save the deposit rate in the site options. I was able to implement deposit payment using a decorator. And pay the rest with a new order. But I don't think it's a good way. Can we pay the rest amount using the same base order ID? I have seen that the total amount cannot be changed using payment decorators, since the methods for receiving data are protected.
I use aimeos-laravel 2022.10
