User logged in > Still asks for account to be created on checkout
I've just noticed that even when im logged in, he still asks to create an account for me. The $this->standardBasket->getCustomerId() is empty. Why is that?
Also, once I've logged in, he displays all fields from the address. How to fix that?
Regards
Regards
Re: User logged in > Still asks for account to be created on checkout
Can you please post a screenshot of what you mean and what do you expect?
I am using 19.4.3 as of this speaking.
Find attached 2 screens and I would expect the visible fields dont change once I am logged in.
- login-error1.jpg (169.73 KiB) Viewed 1981 times
- login-error2.jpg (173.86 KiB) Viewed 1981 times
It's not supported any more, you should upgrade to 19.10. There will be a new 19.10 release this week.
Depends on how you've changed the billing address template. In the default template, whether fields are shown or not depends on the "mandatory", "optional" and "hidden" CSS classes and the configuration settings which defines which fields are mandatory, optional and hidden.
Alright, I will update.
How can my changes influence that, when it's working if I am not logged in? Its just popping up once I am logged in...
