Code documentation
adityabanerjee
Code documentation
Post by adityabanerjee » 22 Nov 2019, 06:11
Hi, I want to learn about the architecture of the Aimeos. Is there documentation that would explain the APIs? My goal is to create my own API for Aimeos. So for that, the documentation would be helpful.
Re: Code documentation
Post by aimeos » 23 Nov 2019, 08:26
A general overview is available here:
https://aimeos.org/docs/Developers/Software_stack
What kind of API do you want to extend? The JSON REST API?
adityabanerjee
Post by adityabanerjee » 23 Nov 2019, 08:39
Yes JSON REST API.
Post by aimeos » 25 Nov 2019, 10:01
The JSON REST API is explained here:
https://aimeos.org/docs/Developers/Client/JSONAPI
To add your own endpoints, please have a look into the code:
https://github.com/aimeos/ai-client-jso ... nt/jsonapi
You should use an existing endpoint class that is close to what you want to implement and copy/paste/adapt it to your needs.
