Deleted
Re: Translation
Post by aimeos » 07 Dec 2019, 10:15
Translation is done in this template:
https://github.com/aimeos/ai-client-htm ... hp#L48-L55
There are already translations for french available according to our translation tool (you need to create a free account and login):
https://www.transifex.com/aimeos/aimeos ... t%3Astock-
Do you want to overwrite that translations? What platform are you using? Laravel, Symfony, TYPO3, etc.?
Re: Translation
Post by aimeos » 07 Dec 2019, 12:11
Can you post the output of "composer show"?
Re: Translation
Post by aimeos » 08 Dec 2019, 10:19
Is the "./ext/ai-client-html/client/i18n/fr" file there (it's a binary file) and does it contain "produit en stock"?
If yes, check if the locale setting in your Symfony application is "fr".
