Translation
BlewSquare
Translation
Post by BlewSquare » 06 Dec 2019, 18:07
Hello everyone , i'm making an e-commerce website and i need your help :D
So i want to translate something but i don't know how , here is the code :
<div class="articleitem stock-actual"
data-prodid="<?= $enc->attr( $this->detailProductItem->getId() ); ?>"
data-prodcode="<?= $enc->attr( $this->detailProductItem->getCode() ); ?>">
</div>
This code is from ai-client-html/client/html/templates/catalog/detail/body-standard.php . The thing i want to translate is the '
' data-prodcode ' ( It return the status about stock so ' unavaible' , ' available ' or ' few product left ' ) . How can i translate it to french ?
Thanks for answering , Blew :)
Re: Translation
Post by aimeos » 07 Dec 2019, 10:15
Translation is done in this template:
https://github.com/aimeos/ai-client-htm ... hp#L48-L55
There are already translations for french available according to our translation tool (you need to create a free account and login):
https://www.transifex.com/aimeos/aimeos ... t%3Astock-
Do you want to overwrite that translations? What platform are you using? Laravel, Symfony, TYPO3, etc.?
BlewSquare
Re: Translation
Post by BlewSquare » 07 Dec 2019, 12:04
Hey back and thank you for answering that fats ^^
So i'm using the laravel package and i dropped the screenshot in the attachments .
I don't know why it's not translating it ...
Capture d’écran 2019-12-07 à 13.03.37.png (10.98 KiB) Viewed 195 times
Re: Translation
Post by aimeos » 07 Dec 2019, 12:11
Can you post the output of "composer show"?
BlewSquare
Re: Translation
Post by BlewSquare » 07 Dec 2019, 17:08
Sure , i dropped it in the attachments
Third
Capture d’écran 2019-12-07 à 18.07.05.png (109.46 KiB) Viewed 191 times
Second
Capture d’écran 2019-12-07 à 18.06.51.png (215.86 KiB) Viewed 191 times
First
Capture d’écran 2019-12-07 à 18.06.36.png (207.92 KiB) Viewed 191 times
Re: Translation
Post by aimeos » 08 Dec 2019, 10:19
Is the "./ext/ai-client-html/client/i18n/fr" file there (it's a binary file) and does it contain "produit en stock"?
If yes, check if the locale setting in your Symfony application is "fr".
BlewSquare
Re: Translation
Post by BlewSquare » 08 Dec 2019, 11:29
Well , i set the FR is position 0 in locale and it works now
Thanks a lot for answering you're helping me a lot ^^
