While Checkout Process Getting Error
awaidqureshi
Post by awaidqureshi » 12 Dec 2019, 13:30
When page goes from /checkout to /checkout/process
getting error
Item with ID "" in "order.id" not found
What can be the issue while processing also not getting any error in madmin_log table.
So kindly guide me to solve this issue
Note: I m using one page process for checkout
Re: While Checkout Process Getting Error
Post by aimeos » 13 Dec 2019, 08:59
The order ID seems to be lost somewhere. It's stored in the user session.
awaidqureshi
Post by awaidqureshi » 13 Dec 2019, 09:59
aimeos wrote: 13 Dec 2019, 08:59 The order ID seems to be lost somewhere. It's stored in the user session.
i have updated aimeos from 2018.10.* to 2019.10.*
after upgrade i m getting this error
Post by aimeos » 14 Dec 2019, 15:07
Can you please post a stack trace of the error. Maybe you need to output one there the exception is caught.
