How can i add product to specific category from my own controller
I m using aimeos 2019.10.*
Please guide how can i can do that in new version
Previously i was using this code to do that
$data = array(
'product' => array(
array(
'code' => $productCode,
'list-type' => 'default',
'list-position' => 0,
'list-config' => [],
'list-start' => null,
'list-end' => null,
'list-status' => 1
$this->addProducts($catalogItem->getId(), $data['product'], 'catalog');
and Add function is doing this:
$context = app()->make('\Aimeos\Shop\Base\Context')->get();
$productManager = \Aimeos\MShop::create($context, 'product');
$listManager = \Aimeos\MShop::create($context, $domain . '/lists');
$listItem = $listManager->createItem();
$listItem->setParentId($parentid);
$listItem->setDomain('product');
$codes = [];
foreach ($data as $entry) {
$codes[$entry['code']] = null;
$search = $productManager->createSearch()->setSlice(0, 0x7fffffff);
$search->setConditions($search->compare('==', 'product.code', array_keys($codes)));
$products = $productManager->searchItems($search);
foreach ($products as $product) {
$codes[$product->getCode()] = $product->getId();
if (!isset($codes[$entry['code']])) {
throw new \RuntimeException(sprintf('No product for code "%1$s" found', $entry['code']));
$listItem->setId(null);
$listItem->setType(7);
$listItem->setDateStart($entry['list-start']);
$listItem->setDateEnd($entry['list-end']);
$listItem->setConfig($entry['list-config']);
$listItem->setPosition($entry['list-position']);
$listItem->setStatus($entry['list-status']);
$listItem->setRefId($codes[$entry['code']]);
$listManager->saveItem($listItem, false);
$data = array(
'product' => array(
array(
'list-end' => null,
'list-status' => 1
$codes = [];
Re: How can i add product to specific category from my own controller
This looks fishy:
The rest should be OK because there have been no changes in that area.
what should be in thisaimeos wrote: ↑16 Dec 2019, 18:40 This looks fishy:The rest should be OK because there have been no changes in that area.Code: Select all
$listItem->setType(?)
thanks
It should be either "default" or "promotion".
