Stock level is not visible on custom page
D-Cell
Post by D-Cell » 18 Dec 2019, 11:02
Hello, dear Aimeos team!
I made a custom controller for separate category page. Here is the code:
class CategoryController extends Controller
    public function treeAction()
		foreach( app( 'config' )->get( 'shop.page.catalog-tree' ) as $name )
			$params['aiheader'][$name] = Shop::get( $name )->getHeader();
			$params['aibody'][$name] = Shop::get( $name )->getBody();
        return Response::view( 'category',
            'params' => $params
			->header( 'Cache-Control', 'private, max-age=10' );
"Category" view looks like:
@extends('layouts.layoutinner')
@section('content')
<div class="container">
    <div class="row">
    {!! $params['aibody']['catalog/stage'] !!}
    {!! $params['aibody']['catalog/lists'] !!}
        </div>
    </div>
@endsection
List of products looks as i need, but the stock level (green/red square) on each product is not visible. In /shop page and product page everything is fine.
Please, tell me, how can i fix it?
Kind regards.
D-Cell
Re: Stock level is not visible on custom page
Post by D-Cell » 18 Dec 2019, 21:43
Sorry, forgot to provide my system info:
Aimeos 2019.10, Laravel 6.2, Fedora 30, PHP 7.3
Post by aimeos » 19 Dec 2019, 07:07
Stock level information is dynamically loaded using an asynchronous request (via JS). Please check if the /stock URL is part of the HTML header (in a <script>/script> tag) and no error is shown in the browser console.
D-Cell
Post by D-Cell » 19 Dec 2019, 18:30
aimeos wrote: 19 Dec 2019, 07:07 Stock level information is dynamically loaded using an asynchronous request (via JS). Please check if the /stock URL is part of the HTML header (in a <script>/script> tag) and no error is shown in the browser console.
Yes! This is it! I didn`t have {!! $params['aiheader']['catalog/lists'] !!} in my layout header. Thank you! :D :D :D
