Want To Change Category Url
awaidqureshi
Post by awaidqureshi » 14 Jan 2020, 14:36
Default category url is http://......com/catgegoryname~categoryid
want to change it to only category name means
Please guide how can i do that
Re: Want To Change Category Url
Post by aimeos » 14 Jan 2020, 15:02
That will be difficult because the category name must be unique then and this is only rarely the case. Furthermore, things get more complicated if category names should translated into several languages.
For products, we've added a resolve() method to the product frontend controller that is used in the HTML client and which finds the product by its name:
https://github.com/aimeos/ai-controller ... #L294-L310
awaidqureshi
Post by awaidqureshi » 20 Jan 2020, 10:18
aimeos wrote:
14 Jan 2020, 15:02
Can i replace this "~" with forward slash if yes then where i have to do the changes
Post by aimeos » 21 Jan 2020, 09:49
Only if you change the product detail routes too because they already use a "/" for separating name and id and/or pos. Otherwise, the Laravel router won't be able to distingish which route to use.
You can add a prefix like /category_name/c/123 to make routes unique.
