Automatical creation of property types in CSV import
boettner
Post by boettner » 17 Jan 2020, 09:00
Hi all,
if I import attributes like so
                attribute {
                    50 = attribute.type
                    51 = attribute.code
                    52 = attribute.label
                    53 = attribute position
Attributes are being automatically created if the type code doesn´t yet exist. This seems not to be the case in a similar manner for properties:
                property {
                    52 = product.property.type
                    53 = product.property.value
                    54 = product.property.languageid
Is this true or am I overlooking something or have an error in my CSV?
Best
Robert.
Re: Automatical creation of property types in CSV import
Post by aimeos » 17 Jan 2020, 09:47
According to the code it should be created:
https://github.com/aimeos/ai-controller ... rd.php#L62
boettner
Post by boettner » 17 Jan 2020, 10:31
Ah tank you. Seems it´s time for an upgrade. We´re still on 18.10.9 with that installation.
Post by aimeos » 17 Jan 2020, 11:00
OK, that's not available in 18.10
