Override catalog/lists/standard/template-body gives error undefined function map()
pixelplumber
Post by pixelplumber » 03 Feb 2020, 01:28
Hi, I created an extension for TYPO3 with your kickstarter and tried to override the client.html.catalog.lists.standard.template-body to remove the list-type (grid/list) widgets. My override template (just a copied body-standard minus lines 139-147) causes a fatal error:
Call to undefined function map()
Line 11: $catPath = $this->get( 'listCatPath', map() );
Do I need something extra in my extensions composer.json to autoload the definition for map()? I only have the default client/src directories, do the template directories need to be added too?
It works if I just use the built-in standard template.
Cheers.
env: TYPO3 9.5.13, Aimeos 9.10. php 7.3 Linux
aimeos/ai-admin-jqadm          2019.10.9
aimeos/ai-admin-jsonadm        2019.10.3
aimeos/ai-client-html          2019.10.12
aimeos/ai-client-jsonapi       2019.10.3
aimeos/ai-controller-frontend  2019.10.8
aimeos/ai-controller-jobs      2019.10.9
aimeos/ai-gettext              2019.10.1
aimeos/ai-typo3                2019.10.5
aimeos/aimeos-core             2019.10.16
aimeos/aimeos-typo3            19.10.4
pixelplumber
Re: Override catalog/lists/standard/template-body gives error undefined function map()
Post by pixelplumber » 03 Feb 2020, 01:44
<facepalm> copied body-standard off ai-client master branch and not the 2019.10 branch.
All good now.
Incidentally, if I try an upgrade to 2020.1 in typo3 the pagination/sorting widgets all stop working - there are no request paramaters attached just the page URL so any clicks just reload the page.
Anyone else seen this?
Post by aimeos » 03 Feb 2020, 08:24
2020.01 is beta so there are some bugs for sure and we will check that.
Post by aimeos » 06 Feb 2020, 17:29
pixelplumber wrote: 03 Feb 2020, 01:44 Incidentally, if I try an upgrade to 2020.1 in typo3 the pagination/sorting widgets all stop working - there are no request paramaters attached just the page URL so any clicks just reload the page.
Doesn't seem to be a general problem. Maybe it's related to the route enhancer configuration you are using.
