No catalog node
No catalog node
Fresh installation of aimeos-laravel (2020.01) on a fresh Laravel (6.14)
Database import without demo data
when calling /shop the message
when trying to add first Category (home) an error message appears: but that artisan command doesn't exists (any more?) and throws an error
shows up.No catalog node for ID ""
btw, in the installation readme it says to runSymfony\Component\Debug\Exception\FatalThrowableError
Argument 1 passed to Aimeos\MShop\Catalog\Item\Standard::setTarget() must be of the type string, null given, called in D:\Development\htdocs\aimeos20\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Catalog\Item\Standard.php on line 432
php artisan aimeos:cache
Re: No catalog node
2020.01 is a beta release for testing only. Please use the 2019.10 LTS release instead if you want to try Aimeos.
Also, you have to add the demo data to get a working frontend out of the box.
Re: No catalog node
well, that's what i did - i tested it and that's what i came up with - result is just FYI
On the other hand i simply followed the instructions on the readme
imho it might make sense either to mention that that's a not working Beta or make install the 2019.10 instead of 2020-01
and the composer command installs the 2020.01Shop package only
Re: No catalog node
Good hint and thanks for mentioning! We've changed that line in the docs.
