Implementing Google maps in checkout
I want to implement google maps so user location is already setup instead of the user having to add his billing address. how can I acheive that?
the second part is related to the checkout process can I have the user pay for something without signing in ( as a guest and just entering his info )?
Laravel version: 6
php version: 7.3.2
Environment: windows
Laravel version: 6
php version: 7.3.2
Re: Implementing Google maps in checkout
You can add the Google Maps code to the address templates and fill in the fields with some Javascript code:
https://github.com/aimeos/ai-client-htm ... t/standard
Sure, this is the default behavior.
