Login link in email
JariVäätäinen
Login link in email
Post by JariVäätäinen » 17 Feb 2020, 15:54
Typo3 9.5.13
Aimeos 19.10.4
Linux Apache2, PHP 7.3
When a customer has ordered something he/she gets an email named "Your new account".
It has a customer's user name, password and login link. It should lead to My account page, but now it leads to webshop's Detail page. How can I correct this?
Thanks for you support!
Re: Login link in email
Post by aimeos » 18 Feb 2020, 11:34
Make sure you've entered the correct page ID in the field for the "Login page ID" in the Aimeos advanced scheduler task you've created for sending the e-mails.
JariVäätäinen
Post by JariVäätäinen » 18 Feb 2020, 14:55
Yes I have. I have entered 5 in Aimeos advanced scheduler task's Account login page ID. It is the same as the id of My account page in Typo3 backend. I have installed Typo3 and Aimeos three times, but the problem still occurs.
The only way I have found to correct this is by hardcoding the My account page address in the file html-body-standard.php, but of course I cannot do it that way, or can I? 8-)
Jari
Post by aimeos » 18 Feb 2020, 17:38
JariVäätäinen wrote: 18 Feb 2020, 14:55 The only way I have found to correct this is by hardcoding the My account page address in the file html-body-standard.php, but of course I cannot do it that way, or can I? 8-)
You shouldn't! ;-)
The problem was that the ID for the login page was't added correctly to the configuration by the scheduler task code. This is fixed now and available in 2019.10.x-dev and will be part of the next release.
JariVäätäinen
Post by JariVäätäinen » 19 Feb 2020, 08:05
Thank You! I will wait for that.
