Adding Telephone in Checkout Address as a Mandatory Field
I want to add the telephone number as a mandatory field.
What I've done is adding it to billing standard.php
And I've changed the html in address Partial standard as follows
but the phone is displayed in disabled mode. How to achieve that.
private $mandatory = array(
'order.base.address.email',
'order.base.address.firstname',
'order.base.address.telephone',
'order.base.address.address1',
'order.base.address.city',
'order.base.address.countryid',
<div class="col <?= ( isset( $css['order.base.address.telephone'] ) ? join( ' ', $css['order.base.address.telephone'] ) : '' ); ?>" data-regex="<?= $testfcn( $regex, 'order.base.address.telephone' ); ?>">
<input type="tel" class="form-control" id="address-<?= $type ?>-telephone<?= $idstr ?>" name="<?= $enc->attr( $this->formparam( array( $fname, 'order.base.address.telephone' ) ) ); ?>"
value="<?= $enc->attr( $testfcn( $addr, 'order.base.address.telephone' ) ); ?>" placeholder="<?= $enc->attr( $this->translate( 'client', 'Telephone' ) ); ?>" <?= $disablefcn( $css, 'order.base.address.telephone' ); ?> >
</div>
Re: Adding Telephone in Checkout Address as a Mandatory Field
You only have to change the configuration and add "order.base.address.telephone" to the mandatory list:
https://aimeos.org/docs/Configuration/C ... /mandatory
You can also change this for the delivery address separately and modify the optional and hidden fields.
