Getting data from database to Admin interface
I want to extend the admin interface to add a page that show the users request services ( I have added a controller and a view for users to add services to the table named "suggested_services" and I want Admin to view them ). I copied the Order folders in JqAdm and I tried to modify it to get the data I want with no luck. which files and methods I should be implementing ? thanks in advance Aimeos
Re: Getting data from database to Admin interface
You can use the Log panel as reference because it's the easiest one if you only want to view data. Copy the Factory.php and Standard.php file and replace "Log" and "log" with "Suggest" and "suggest".
Use your Laravel controllers to retrieve the data and add them to the view to render them in the search() method:
https://github.com/aimeos/ai-admin-jqad ... hp#L31-L89
You need to have a template in ./templates/suggest/list-standard.php that renders the output like this:
https://github.com/aimeos/ai-admin-jqad ... plates/log
thanks for your suggestion I am using the log panel source and template now and renamed the files and the occurrence of the variables and namespace and I have added a link to the navbar And It did show an empty log page but there is an error
And btw I added the navbar link in the admin.php in the jqadm array but it removes the dashboard link from the admin panel.
the second part, I did retrieve the data in my controller ( I put the controller in the App/Http/Controllers ) is that the correct path for aimeos and how to connect it to the view in the Jqadm suggest folder. thanks
Class "\Aimeos\MAdmin\Suggest\Manager\Factory" not available
'navbar' => [
suggest,
You have to replace that part in your new code by your own one:
https://github.com/aimeos/ai-admin-jqad ... hp#L38-L46
Best by using the Laravel DB facade to retrieve the data you need and add it to the view.
To show the new panel in the navbar, you need to add it to the navbar configuration but also assign permissions for your user group (super, admin or editor) like this:
https://github.com/aimeos/ai-admin-jqad ... #L455-L471
