Get Mini Basket With Product Images also
awaidqureshi
Post by awaidqureshi » 07 Feb 2019, 14:12
Is There Any Method In Which I can get mini basket with product images also.
Please give Info about that.
Re: Get Mini Basket With Product Images also
Post by aimeos » 08 Feb 2019, 13:01
You can change the template and add the product image link here:
https://github.com/aimeos/ai-client-htm ... d.php#L171
You can get the URL by using:
<img src="<?= $this->content( $product->getMediaUrl() ) ?>" />
The methods of the ordered product are documented there:
https://aimeos.org/api/latest/class-Aim ... Iface.html
loeffe1
Post by loeffe1 » 02 Mar 2020, 15:52
How would we need to update the AimeosBasketMini updateBasket function to show the image without having to reload the page after adding a product to the basket?
I have modified my mini basket template and added the below to the AimeosBasketMini updateBasket function but the image will only show after a page reload
$(".thumbnail--container img", product).attr("src", entry.attributes['order.base.product.mediaUrl']);
I am assuming that order.base.product.mediaUrl does not exists as my src is updated with (unknown)
Post by aimeos » 03 Mar 2020, 08:25
Dump the response or have a look into the web inspector of your browser to see the structure of the data.
loeffe1
Post by loeffe1 » 07 Jul 2020, 13:08
The attribute is called order.base.product.mediaurl, not order.base.product.mediaUrl. I still had to edit the script to modify the path of the preview image but now it is working.
harshithvemula
Post by harshithvemula » 09 Oct 2020, 04:05
I have added the product image to the mini cart but it updates only after reloading the page. i have tried adding code to update basket function but it didn't worked .please help me
parmonov98
Post by parmonov98 » 09 Oct 2020, 17:34
how about to get a url of the product in basket?
I didn't find an url returner method on https://aimeos.org/api/latest/class-Aim ... ndard.html.
https://imgur.com/3vtF4is
there is not url. or how can I generate it?
Post by aimeos » 10 Oct 2020, 08:55
What's your code for adding the image in the mini basket?
The basket product itself has no URL because it depends on the configured target page. You can generate the URL easily using the URL view helper using:
$this->link( 'client/html/catalog/detail/url', [<params>] )
parmonov98
Post by parmonov98 » 10 Oct 2020, 12:53
aimeos wrote: 10 Oct 2020, 08:55 What's your code for adding the image in the mini basket?
be kind, tell me what to pass in there as params?
Post by aimeos » 11 Oct 2020, 08:57
The parameters your can pass are described here:
https://aimeos.org/docs/latest/frontend ... ter-names/
