ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY
Re: ALTER TABLE users_address ADD CONSTRAINT fk_lvuad_pid FOREIGN KEY
Post by aimeos » 07 Mar 2020, 10:58
The setup is done by setup tasks, which are more advanced than migrations because you can define pre- and post-dependencies between tasks.
Your problem is that the "id" of the users table has a different definition than the standard one, e.g. it's not "unsigned":
https://github.com/aimeos/ai-laravel/bl ... er.php#L17
