not load complate
- parsahostco
not load complate
hi
after install in localhost
- Capture.JPG (30.64 KiB) Viewed 776 times
Re: not load complate
Your domain must point to the public folder of your installation. It's not allowed that "/public/" is a subfolder of your domain. If you use "php artisan serve", it will be automatically correct. When using the integrated PHP web server, it must be:
For Apache or Nginx, your document root must point to the ./public/ folder of your installation, not to the base directory of your application.
php -S localhost -t public
