Hosting aimeos on live server
- octobercms
I am new to aimeos and just installed it.When I run the application using php artisan serve in local server, everything works perfectly. But when I hosted it online or tried to open it using XAAMP server from htdocs folder, the CSS and images are not loaded.
I have kept the public folder in the root directory of the project but I got as in the image shown.
Re: Hosting aimeos on live server
The public folder needs to be the document root, i.e https://yourdomain.tld/ needs to show the Laravel start page.
- octobercms
The public folder is already the document root. When I enter https://mydomain.tld/ it redirects to https://yourdomain.tld/shop but no images and CSS are available for the site. When I inspect the image, I got this:
I could not understand how to setup aimeos. When I run it using php artisan serve in my local server, everything is working perfectly but the same problem occurs when I try to access it using localhost/aimeos/shop in my local setup.
<img class="lazy-image" src="data:image/gif;base64,R0lGODlhAQABAIAAAP///////yH5BAEEAAEALAAAAAABAAEAAAICTAEAOw==" data-src="https://demo.aimeos.org/media/1.jpg" data-srcset="https://demo.aimeos.org/media/1.jpg 1w, https://demo.aimeos.org/media/1-big.jpg 250w" alt="Demo: Article 1.jpg">
Maybe there's a problem with your server configuration. Can you check in the inspector of your browser (network tab) the response from the server for the JS and CSS files?
- octobercms
I have not changed any default configurations or path after installation of aimeos. I have just made the public directory as root. I got the following error messages:
- Capture.PNG (37.87 KiB) Viewed 2209 times
Please make sure there's no misconfiguration of your live server and the app.js file is available in the ./public/js/ directory of your installation.
