Error after cleaning unnessecary elements
after removing some services and suppliers, I got the following error:
(1/1) Aimeos\Client\Html\Exception
What is wrong here?
Thanks,
Kurt
Class "\Aimeos\Client\Html\Common\Decorator\Service" not found
in xxxxx/ext/ai-client-html/client/html/src/Client/Html/Common/Factory/Base.php line 63
Thanks,
Kurt
Re: Error after cleaning unnessecary elements
Seems like you've added the string "Service" to one of your payment or delivery options behind a comma, e.g.
That doesn't work because there's no "Service" decorator.
Default,Service
Hmm, okay, I will check
