Copy the data(products,prices,stock,categories) to aimeos using native sql requests
"aimeos/aimeos-laravel": "~2019.10"
windows 10: 64
Laravel Framework 6.18.3
I use stock management software which uses a database, I try to copy the data(products,prices,stock,categories) directly from the software to the aimeos database.
I copied the following tables using native sql requests:
/// nId_produit_mshop_product : foreign key table id mshop_product
mshop_product,
//// ajouter un mshop_product
mshop_product.siteid=1
mshop_product.dataset=""
mshop_product.type="default"
mshop_product.code=Produit.Code_Produit
mshop_product.label=Produit.Description
mshop_product.config="[]"
mshop_product.start=DateSys()
mshop_product.end=""
mshop_product.status=1
mshop_product.mtime=DateSys()
mshop_product.ctime=DateSys()
mshop_product.editor=COMBO_Combo..ValeurAffichée
mshop_product.target=""
//// add un mshop_product_list
mshop_product_list.parentid=nId_produit_mshop_product /// id de table mshop_product
mshop_product_list.siteid=1
mshop_product_list.key="attribute|default|1"
mshop_product_list.type="default"
mshop_product_list.domain="attribute"
mshop_product_list.refid=1
mshop_product_list.start=DateHeureSys()
mshop_product_list.config="[]"
mshop_product_list.pos=0
mshop_product_list.status=1
mshop_product_list.mtime=DateHeureSys()
mshop_product_list.ctime=DateHeureSys()
mshop_product_list.editor="contact@email.com"
HAdd(mshop_product_list)
// ADD mshop_index_text
mshop_index_text.prodid = nId_produit_mshop_product
mshop_index_text.prodid=nId_produit_mshop_product
mshop_index_text.siteid=1
mshop_index_text.langid="fr"
mshop_index_text.url=Produit.Description
mshop_index_text.name=Produit.Description
mshop_index_text.content=Produit.Description
mshop_index_text.mtime=DateHeureSys()
HAdd(mshop_index_text)
// ADD mshop_index_catalog
mshop_index_catalog.prodid=mshop_product.id
mshop_index_catalog.siteid=1
mshop_index_catalog.catid=1
mshop_index_catalog.listtype="default"
mshop_index_catalog.pos=0
mshop_index_catalog.mtime=DateHeureSys()
IF HAdd(mshop_index_catalog) THEN
END
// ADD mshop_stock
mshop_stock.siteid=1
mshop_stock.type="default"
mshop_stock.productcode=Produit.Code_Produit
//mshop_stock.stocklevel
//mshop_stock.backdate
//mshop_stock.timeframe
mshop_stock.mtime=DateHeureSys()
mshop_stock.ctime=DateHeureSys()
mshop_stock.editor=COMBO_Combo..ValeurAffichée
HAdd(mshop_stock)
//mshop_index_price
mshop_index_price.prodid=nId_produit_mshop_product
mshop_index_price.siteid=1
mshop_index_price.currencyid="MAD"
mshop_index_price.value=Produit.Prix_Vente
mshop_index_price.mtime=DateHeureSys()
HAdd(mshop_index_price)
The products are displayed on the admin part but not on the home page.
for it to appear on the homepage I have to assign them to a category.
I don't want to go to the website every time and do it manually for each product.
cordially
windows 10: 64
mshop_product,
END
// ADD mshop_stock
HAdd(mshop_stock)
//mshop_index_price
cordially
Re: Copy the data(products,prices,stock,categories) to aimeos using native sql requests
You can create the categories and add an entry in the mshop_catalog_list table referening the product. Afterwards, you have to rebuild the product index by running the index/rebuild job controller.
