No item found for conditions: Array ( [locale.site.code] => default ) error occured when taking Aimeos Shop
After importing the page tree in Typo3 version 9.5.14, An error as
"No item found for conditions: Array ( [locale.site.code] => default )" showing while taking the Aimeos Shop in Backend.
- Screenshot (1).png (46.62 KiB) Viewed 3271 times
Re: No item found for conditions: Array ( [locale.site.code] => default ) error occured when taking Aimeos Shop
Please make sure, you execute the update script of the Aimeos extension in the extension manager (again) and it succeeds without any error message at the end.
yes i done that many times before...but it was not working ..
I just deactivate it and again installed ..now its working...
Thank you for reply
Thank you for reply
Can you post the complete output of the setup script from the extension manager?
I have the same problem, have you found a solution?
Did you deactive/active the extension and checked if the setup script executed without error at the end of the output?
I had the same problem and fixed with this solution :
typo3-and-flow-neoscms-f16/no-item-foun ... tml#p11289
