Products out of stock
g-trema
Post by g-trema » 31 Mar 2020, 06:31
Hello!
is there an easy way to avoid displaying products that are out of stock?
Thank you!
PHP 7.2.28
Laravel Framework 6.18.1
Aimeos 2019.10
Re: Products out of stock
Post by aimeos » 01 Apr 2020, 07:22
Not directly. Stocks and products are separated because stocks are highly volatile and would prevent caching. Thus, they are added via Javascript by a separate request and that makes it more difficult to show only products that are in stock.
The "easiest" way would be to hide products via CSS in the list view depending on the stock request (which returns Javascript, so you can add your code to the template easily).
g-trema
Post by g-trema » 05 Apr 2020, 12:45
Okay, got it!
Thank you very much for the answer!
PHP 7.2.28
Aimeos 2019.10
