XML import of product options
cnoelker
Post by cnoelker » 07 Apr 2020, 11:18
I checked the sample product-import.xml file for a way to import the options for a product. I expected this to be one of the attribute items, but could not find a suitable lists.type .
Is there a way to import these?
Claudia
Re: XML import of product options
Post by aimeos » 08 Apr 2020, 17:38
Use list type "config" for product options
cnoelker
Post by cnoelker » 09 Apr 2020, 07:26
Thank you, this works.
If an option is available for all of the variants of a select product (and with the same values), can I then add the option just at the select-product? Or is it necessary to add the options for each of the default-products?
Post by aimeos » 10 Apr 2020, 12:43
Just for the selection product. If you add config attributes to the articles, they won't shown in the frontend at the moment.
cnoelker
Post by cnoelker » 22 May 2020, 13:46
BTW, the other possible option can be imported with list.type="custom"
