Image not displaying when taking copy of a product
Athulya
Post by Athulya » 07 Apr 2020, 07:33
While taking a copy and save a product, it not displaying the image in it
Re: Image not displaying when taking copy of a product
Post by aimeos » 08 Apr 2020, 07:51
Thank you for the hint. We can confirm the problem and are working on a solution.
Post by aimeos » 08 Apr 2020, 10:45
The issue has been fixed and will be part of the next release.
If you are using composer, you can test the new code executing:
composer req aimeos/aimeos-core:2019.10.x-dev
