Category Page
Category Page
I want to show a page with just one category on it (ie: all products from one category).
I can do this below to pull the category page, but how do I specify the correct category? I can't figure out how to pass the category ID variable into it.
Route::match( array( 'GET', 'POST' ), '/my-category/', array(
'as' => 'aimeos_shop_catalog',
'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction'
Re: Category Page
You have to create your own controller and action with a copy of the catalog::list action. Then, set the category ID as default value in that action:
See: https://aimeos.org/docs/Configuration/C ... id-default
and https://aimeos.org/docs/Laravel/Extend_Aimeos
$context->getConfig()->set( 'client/html/catalog/lists/catid-default', 123 );
