Profile page Error
Profile page Error
Laravel 7.10.3
Aimeos 2020.04
PHP 7.4.5
Homestead 10.8.0
Windows 10
I have created a new Laravel project, than installed Aimeos following the guide.
When I register as a user, and click on the "Profile" link, I'm taken to http://myshop.test/profile?site=default ... rrency=EUR and I get the error mesage:
Looking at madmin_log table, I get two errors for the same request:
Aimeos 2020.04
PHP 7.4.5
Homestead 10.8.0
Windows 10
A non-recoverable error occured
andRoute [] not defined.
#0 /home/vagrant/Code/mica/shop/ext/ai-laravel/lib/custom/src/MW/View/Helper/Url/Laravel5.php(62): Illuminate\Routing\UrlGenerator->route()
#1 [internal function]: Aimeos\MW\View\Helper\Url\Laravel5->transform()
#2 /home/vagrant/Code/mica/shop/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(88): call_user_func_array()
#3 /home/vagrant/Code/mica/shop/ext/ai-client-html/client/html/templates/account/profile/address-body-standard.php(30): Aimeos\MW\View\Standard->__call()
#4 /home/vagrant/Code/mica/shop/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(257): include('/home/vagrant/C...')
#5 /home/vagrant/Code/mica/shop/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(239): Aimeos\MW\View\Standard->includeFile()
#6 /home/vagrant/Code/mica/shop/ext/ai-client-html/client/html/src/Client/Html/Account/Profile/Address/Standard.php(100): Aimeos\MW\View\Standard->render()
#7 /home/vagrant/Code/mica/shop/ext/ai-client-html/client/html/src/Client/Html/Account/Profile/Standard.php(92): Aimeos\Client\Html\Account\Profile\Address\Standard->getBody()
#8 /home/vagrant/Code/mica/shop/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Controller/AccountController.php(36): Aimeos\Client\Html\Account\Profile\Standard->getBody()
#9 [internal function]: Aimeos\Shop\Controller\AccountController->indexAction()
#10 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): call_user_func_array()
#11 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#12 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Route.php(239): Illuminate\Routing\ControllerDispatcher->dispatch()
#13 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Route.php(196): Illuminate\Routing\Route->runController()
#14 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Router.php(685): Illuminate\Routing\Route->run()
#15 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#16 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#18 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#20 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(76): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#22 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#24 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(62): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#26 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#27 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#28 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#29 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(66): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#31 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Router.php(687): Illuminate\Pipeline\Pipeline->then()
#33 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Router.php(662): Illuminate\Routing\Router->runRouteWithinStack()
#34 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Router.php(628): Illuminate\Routing\Router->runRoute()
#35 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Routing/Router.php(617): Illuminate\Routing\Router->dispatchToRoute()
#36 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\Routing\Router->dispatch()
#37 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#38 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#40 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#42 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#44 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(63): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle()
#46 /home/vagrant/Code/mica/shop/vendor/fruitcake/laravel-cors/src/HandleCors.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle()
#48 /home/vagrant/Code/mica/shop/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#50 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(140): Illuminate\Pipeline\Pipeline->then()
#52 /home/vagrant/Code/mica/shop/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(109): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#53 /home/vagrant/Code/mica/shop/public/index.php(55): Illuminate\Foundation\Http\Kernel->handle()
#54 {main}
Re: Profile page Error
Thank you for the hint! Can you please execute
and see if it works now?
composer req aimeos/aimeos-laravel:2020.04.x-dev
Thank you!
It's working now.
Thank you!
It's working now.
I'm getting the same error on a brand new clean build.
is there a way to fix this without using -dev dependency please.
