Email Notification not working when order Placed
Re: Email Notification not working when order Placed
Post by aimeos » 28 Apr 2020, 06:56
You have no orders placed, so no e-mails will be sent!
SamKbizsoft
Post by SamKbizsoft » 28 Apr 2020, 13:53
Actually order was deleted thats why mshop tables showing blank.
Now I created Test order over website. Here is the Mshop Tables Screenshots given below:
mshop_order_status : https://prnt.sc/s7ewu7
mshop_order : https://prnt.sc/s7exwe
Now Order placed over website but still email received. Please check and let me know your words.
Thank you
Post by aimeos » 29 Apr 2020, 09:24
The payment status of your order is unfinished (-1), so no order confirmation e-mail will be sent. They are only sent for status 5 and 6 (authorized and received)
SamKbizsoft
Post by SamKbizsoft » 30 Apr 2020, 04:28
Is there any possible way to send email when order created without payment?
Post by aimeos » 01 May 2020, 07:14
No, you need a payment service to change payment status, even if it's only a fake payment option with the provider "PostPay" that you doesn't show in the checkout (hidden by CSS) but added to the basket.
SamKbizsoft
Post by SamKbizsoft » 08 May 2020, 09:08
I tested order with Post pay Method and didn't get any email after place order. Please check at https://prnt.sc/sd236f
Here is the some screenshots after Set Post Paymenthod over website.
Payment Activated : https://prnt.sc/sd236f
mshop_order Table : https://prnt.sc/sd2bs3
Orders : https://prnt.sc/sd2cpu
Logs : https://prnt.sc/sd2dmm
Please let me know how we can fix this issue.
Thank you
Post by aimeos » 09 May 2020, 09:31
The order table still doesn't show an order with a payment status of 5 or 6 so no e-mails are sent: https://prnt.sc/sd2bs3
Your service configuration seems to be correct and should set the payment status to 5 if you place an order in the frontend when "Invoice" as payment method is selected.
SamKbizsoft
Post by SamKbizsoft » 12 May 2020, 14:12
Hello
Thank you for your valuable time. I updated 5 value to mshop_table through cron and email working for customer.
But need to send notification email to admin as well. I used some typo script here but didn't get any notification after place order. Please check at https://prnt.sc/sfdyks
Please let me know the solution as well
Thank you
Post by aimeos » 14 May 2020, 08:14
That should work according to the code:
https://github.com/aimeos/ai-client-htm ... #L276-L303
You can try to use
client.html.email.payment.bcc-email = info@casmart.ch
instead but both should work and has worked in the past for other users.
