How to add decorator to config using Factory
Hi, I am new in aimeos.
Recently I read that in order to make changes to default views first I need to create a decorator and then add that decorator to the config .
Can anyone tell me how to add a decorator to config.
Thanks in advance.
Thanks in advance.
Re: How to add decorator to config using Factory
You can use decorators in many places. What would you like to decorate? A manager, a controller, a client class, etc.?
