Can't delete multiple products from admin
JoseBibiloni
Post by JoseBibiloni » 24 Apr 2020, 03:50
When trying to delete multiple products using the checkboxes and then the x at the top of the checkboxes I get a confirmation asking if I want to delete the items selected and lists them but once you confirm I get the following error:
"Class "\Aimeos\Admin\JQAdm\Product\En\Factory" not available"
Using Laravel 5.8, Aimeos 2020.04, PHP 7.2, Ubuntu 18.04
Re: Can't delete multiple products from admin
Post by aimeos » 25 Apr 2020, 08:01
Laravel 5.x has a routing bug assigning any parameter to an optional route parameter. If you can, upgrade to Laravel 6
JoseBibiloni
Post by JoseBibiloni » 29 Apr 2020, 03:51
aimeos wrote: 25 Apr 2020, 08:01 Laravel 5.x has a routing bug assigning any parameter to an optional route parameter. If you can, upgrade to Laravel 6
Would love to but there are limitations I can't control that makes me stay in 5.x Is there another workaround I could do? Anything I should search for specifically?
Post by aimeos » 29 Apr 2020, 17:19
Possible workaround could be to add an empty "id" parameter here if it doesn't exist:
https://github.com/aimeos/ai-admin-jqad ... #L515-L516
JoseBibiloni
Post by JoseBibiloni » 13 May 2020, 18:17
aimeos wrote: 29 Apr 2020, 17:19 Possible workaround could be to add an empty "id" parameter here if it doesn't exist:
Do you mean something like $searchParams['id'] = ''; ?
I added that but the problem persists. I am looking to upgrade but no success yet so I am trying the workaround.
Post by aimeos » 14 May 2020, 17:43
That workaround works: https://github.com/aimeos/ai-admin-jqad ... 5c55590b28
Use
composer req aimeos/ai-admin-jqadm:2020.04.x-dev
until the new version is tagged.
JoseBibiloni
Post by JoseBibiloni » 15 May 2020, 23:26
aimeos wrote: 14 May 2020, 17:43 That workaround works: https://github.com/aimeos/ai-admin-jqad ... 5c55590b28
Use
worked perfectly thank you!
