Adding product variaties - Selection _ extra input
Doggiefield
Post by Doggiefield » 18 May 2020, 01:22
When adding a new select type product I can add new subproducts in the variaties tab, but for each subproduct I also need to be able to set the price / stock and hidden attributes.
Is it possible to add those fields in the selection for each subproduct?
Re: Adding product variaties - Selection _ extra input
Post by aimeos » 18 May 2020, 07:32
That would be too much for the variants tab esp. as others may want to add images and texts too. You can jump to the artices after you've saved the selection product and add the required data there.
Doggiefield
Post by Doggiefield » 18 May 2020, 10:39
Thank you for your answer,
I get your point and I agree, it would be too much if you add complete pricing blocks for each subproduct. But I only need the following fields:
- price value (final price) (optional)
- Option to add hidden attributes simmular to adding variant attributes
Post by aimeos » 18 May 2020, 11:16
You can overwrite the product selection subpart and template (includeing the JS) in your own extension to be able to manage that data in the variants tab.
Doggiefield
Post by Doggiefield » 18 May 2020, 12:23
Thank you very much for the quick responces.
I'm going to take a look at this, I hope I can add these and use the product datasets to add these lines.
