Configure different databases for eache site
liviu
Post by liviu » 22 May 2020, 07:14
I sow that is possible to configure the application to use different db for a specific subdomain of tables: https://aimeos.org/docs/Laravel/Several_databases
Is it possible to configure a different database for each defined site?
Thanks, best regards!
Re: Configure different databases for eache site
Post by aimeos » 22 May 2020, 07:22
No, because then you can also use one installation for each site if they should be independent.
liviu
Post by liviu » 25 May 2020, 07:13
Yes, you are right. The ideal would be to keep general settings common and to set up a dedicated DB for order and customer domains for each site. Is this possible?
Post by aimeos » 25 May 2020, 17:27
You can use one database for customers, one for orders and one for the rest but not per site. Per site is only possible if you have one installation per site.
