Multiple sites frontend Not displaying (only default site is displayed)
chemwen0
Post by chemwen0 » 18 Apr 2020, 03:39
Hi, I created a multivendor shop with the Aimeos Laravel shop, however, only the default or rather the first site I created has its products displayed on the frontend. The other sites have the products being added to the products table but are not displayed. All the products have categories. I tried clearing cache and rebuilding the index and even resaving items in the sites but none of these options have helped in any way. What am I not doing right?
I'm using Laravel 6.18.6, php 7.4.3 and aimeos/aimeos-laravel: ~2020.04 on windows os
Re: Multiple sites frontend Not displaying (only default site is displayed)
Post by aimeos » 19 Apr 2020, 07:54
Did you configure your routes for multiple shops?
https://aimeos.org/docs/Laravel/Configu ... iple_shops
chemwen0
Post by chemwen0 » 25 Apr 2020, 03:01
Yes I configured. however, I noticed that the different shops were accessed from different URLs thus was able to access the sites eventually. Thank you
albcamargo61
Post by albcamargo61 » 20 May 2020, 11:08
Did you solve this issue? I have the same problem.
albcamargo61
Post by albcamargo61 » 21 May 2020, 13:32
Does any one have a solution? I'm stucked.
Post by aimeos » 22 May 2020, 07:19
Can you please post your shop/config.php file (without credentials) and the output of "php artisan route:list"?
albcamargo61
Post by albcamargo61 » 22 May 2020, 16:58
Thanks.
My env:
Linux version 4.15.0-101-generic (buildd@lgw01-amd64-003) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #102-Ubuntu
PHP 7.2.24-0ubuntu0.18.04.4 (cli) (built: Apr 8 2020 15:45:57) ( NTS )
Laravel Framework 6.18.14
URL: biioh.co
My shop.php
<?php
return [
'apc_enabled' => false, // enable for maximum performance if APCu is availalbe
'apc_prefix' => 'aimeos:', // prefix for caching config and translation in APCu
'pcntl_max' => 4, // maximum number of parallel command line processes when starting jobs
'routes' => [
'jsonapi' => ['prefix' => 'colanta/jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => 'colanta/profile', 'middleware' => ['web', 'auth']],
'colanta' => ['prefix' => 'colanta', 'middleware' => ['web']],
'page' => [
'account-index' => [ 'account/profile','account/subscription','account/history','account/favorite','account/watch','basket/mini','catalog/session','locale/select' ],
'basket-index' => [ 'basket/bulk', 'basket/standard','basket/related' ],
'catalog-count' => [ 'catalog/count' ],
'catalog-detail' => [ 'basket/mini','catalog/stage','catalog/detail','catalog/session','locale/select' ],
'catalog-list' => [ 'basket/mini','catalog/filter','catalog/stage','catalog/lists','locale/select' ],
'catalog-stock' => [ 'catalog/stock' ],
'catalog-suggest' => [ 'catalog/suggest' ],
'catalog-tree' => [ 'basket/mini','catalog/filter','catalog/stage','catalog/lists' ],
'checkout-confirm' => [ 'checkout/confirm' ],
'checkout-index' => [ 'checkout/standard' ],
'checkout-update' => [ 'checkout/update' ],
'resource' => [
'db' => [
'adapter' => config('database.connections.mysql.driver', 'mysql'),
'host' => config('database.connections.mysql.host', '127.0.0.1'),
'port' => config('database.connections.mysql.port', '3306'),
'socket' => config('database.connections.mysql.unix_socket', ''),
'database' => config('database.connections.mysql.database', 'forge'),
'username' => config('database.connections.mysql.username', 'forge'),
'password' => config('database.connections.mysql.password', ''),
'stmt' => ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"],
'limit' => 3, // maximum number of concurrent database connections
'defaultTableOptions' => [
'charset' => config('database.connections.mysql.charset'),
'collate' => config('database.connections.mysql.collation'),
//acamargo
//To show products from all sites in the frontend, you have to add this to your Laravel ./config/shop.php:
'frontend' => array(
'mshop' => array(
'common' => array(
'manager' => array(
'sitecheck' => 0
'admin' => [],
'client' => [
'html' => [
'basket' => [
'cache' => [
// 'enable' => false, // Disable basket content caching for development
'catalog' => [
'selection' => [
'type' => [
'color' => 'radio',
'length' => 'radio',
'width' => 'radio',
'controller' => [
'i18n' => [
'madmin' => [
'cache' => [
'manager' => [
// 'name' => 'None', // Disable caching for development
'log' => [
'manager' => [
'standard' => [
// 'loglevel' => 7, // Enable debug logging into madmin_log table
'mshop' => [
'command' => [
'frontend' => [
'backend' => [
And the output of "php artisan route:list"
| Domain | Method | URI | Name | Action | Middleware |
| | GET|HEAD | / | | Closure | web |
| | GET|HEAD | admin | aimeos_shop_admin | Aimeos\Shop\Controller\AdminController@indexAction | web |
| | GET|POST|HEAD | admin/{site}/jqadm/copy/{resource}/{id} | aimeos_shop_jqadm_copy | Aimeos\Shop\Controller\JqadmController@copyAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/create/{resource} | aimeos_shop_jqadm_create | Aimeos\Shop\Controller\JqadmController@createAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/delete/{resource}/{id?} | aimeos_shop_jqadm_delete | Aimeos\Shop\Controller\JqadmController@deleteAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/export/{resource} | aimeos_shop_jqadm_export | Aimeos\Shop\Controller\JqadmController@exportAction | web,auth |
| | GET|HEAD | admin/{site}/jqadm/file/{type} | aimeos_shop_jqadm_file | Aimeos\Shop\Controller\JqadmController@fileAction | web,auth |
| | GET|HEAD | admin/{site}/jqadm/get/{resource}/{id} | aimeos_shop_jqadm_get | Aimeos\Shop\Controller\JqadmController@getAction | web,auth |
| | POST | admin/{site}/jqadm/save/{resource} | aimeos_shop_jqadm_save | Aimeos\Shop\Controller\JqadmController@saveAction | web,auth |
| | GET|POST|HEAD | admin/{site}/jqadm/search/{resource} | aimeos_shop_jqadm_search | Aimeos\Shop\Controller\JqadmController@searchAction | web,auth |
| | OPTIONS | admin/{site}/jsonadm/{resource?} | aimeos_shop_jsonadm_options | Aimeos\Shop\Controller\JsonadmController@optionsAction | web,auth |
| | PUT | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_put | Aimeos\Shop\Controller\JsonadmController@putAction | web,auth |
| | POST | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_post | Aimeos\Shop\Controller\JsonadmController@postAction | web,auth |
| | PATCH | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_patch | Aimeos\Shop\Controller\JsonadmController@patchAction | web,auth |
| | GET|HEAD | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_get | Aimeos\Shop\Controller\JsonadmController@getAction | web,auth |
| | DELETE | admin/{site}/jsonadm/{resource}/{id?} | aimeos_shop_jsonadm_delete | Aimeos\Shop\Controller\JsonadmController@deleteAction | web,auth |
| | GET|HEAD | api/user | | Closure | api,auth:api |
| | OPTIONS | colanta/jsonapi/{resource?} | aimeos_shop_jsonapi_options | Aimeos\Shop\Controller\JsonapiController@optionsAction | web,api |
| | DELETE | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_delete | Aimeos\Shop\Controller\JsonapiController@deleteAction | web,api |
| | GET|HEAD | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_get | Aimeos\Shop\Controller\JsonapiController@getAction | web,api |
| | POST | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_post | Aimeos\Shop\Controller\JsonapiController@postAction | web,api |
| | PUT | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_put | Aimeos\Shop\Controller\JsonapiController@putAction | web,api |
| | PATCH | colanta/jsonapi/{resource} | aimeos_shop_jsonapi_patch | Aimeos\Shop\Controller\JsonapiController@patchAction | web,api |
| | GET|POST|HEAD | colanta/profile | aimeos_shop_account | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|POST|HEAD | colanta/profile/download/{dl_id} | aimeos_shop_account_download | Aimeos\Shop\Controller\AccountController@downloadAction | web,auth |
| | GET|POST|HEAD | colanta/profile/favorite/{fav_action?}/{fav_id?}/{d_name?}/{d_pos?} | aimeos_shop_account_favorite | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|POST|HEAD | colanta/profile/watch/{wat_action?}/{wat_id?}/{d_name?}/{d_pos?} | aimeos_shop_account_watch | Aimeos\Shop\Controller\AccountController@indexAction | web,auth |
| | GET|HEAD | home | home | App\Http\Controllers\HomeController@index | web,auth |
| | GET|HEAD | login | login | App\Http\Controllers\Auth\LoginController@showLoginForm | web,guest |
| | POST | login | | App\Http\Controllers\Auth\LoginController@login | web,guest |
| | POST | logout | logout | App\Http\Controllers\Auth\LoginController@logout | web |
| | POST | password/confirm | | App\Http\Controllers\Auth\ConfirmPasswordController@confirm | web,auth |
| | GET|HEAD | password/confirm | password.confirm | App\Http\Controllers\Auth\ConfirmPasswordController@showConfirmForm | web,auth |
| | POST | password/email | password.email | App\Http\Controllers\Auth\ForgotPasswordController@sendResetLinkEmail | web |
| | POST | password/reset | password.update | App\Http\Controllers\Auth\ResetPasswordController@reset | web |
| | GET|HEAD | password/reset | password.request | App\Http\Controllers\Auth\ForgotPasswordController@showLinkRequestForm | web |
| | GET|HEAD | password/reset/{token} | password.reset | App\Http\Controllers\Auth\ResetPasswordController@showResetForm | web |
| | GET|HEAD | privacy | aimeos_shop_privacy | Aimeos\Shop\Controller\PageController@privacyAction | |
| | POST | register | | App\Http\Controllers\Auth\RegisterController@register | web,guest |
| | GET|HEAD | register | register | App\Http\Controllers\Auth\RegisterController@showRegistrationForm | web,guest |
| | GET|POST|HEAD | shop | aimeos_shop_list | Aimeos\Shop\Controller\CatalogController@listAction | web |
| | GET|POST|HEAD | shop/basket | aimeos_shop_basket | Aimeos\Shop\Controller\BasketController@indexAction | web |
| | GET|POST|HEAD | shop/checkout/{c_step?} | aimeos_shop_checkout | Aimeos\Shop\Controller\CheckoutController@indexAction | web |
| | GET|POST|HEAD | shop/confirm/{code?} | aimeos_shop_confirm | Aimeos\Shop\Controller\CheckoutController@confirmAction | web |
| | GET|POST|HEAD | shop/count | aimeos_shop_count | Aimeos\Shop\Controller\CatalogController@countAction | web |
| | GET|POST|HEAD | shop/pin/{pin_action}/{pin_id}/{d_name} | aimeos_shop_session_pinned | Aimeos\Shop\Controller\CatalogController@detailAction | web |
| | GET|POST|HEAD | shop/stock | aimeos_shop_stock | Aimeos\Shop\Controller\CatalogController@stockAction | web |
| | GET|POST|HEAD | shop/suggest | aimeos_shop_suggest | Aimeos\Shop\Controller\CatalogController@suggestAction | web |
| | GET|POST|HEAD | shop/{d_name}/{d_pos?}/{d_prodid?} | aimeos_shop_detail | Aimeos\Shop\Controller\CatalogController@detailAction | web |
| | GET|POST|HEAD | shop/{f_name}~{f_catid} | aimeos_shop_tree | Aimeos\Shop\Controller\CatalogController@treeAction | web |
| | GET|HEAD | terms | aimeos_shop_terms | Aimeos\Shop\Controller\PageController@termsAction | |
| | GET|POST|HEAD | update | aimeos_shop_update | Aimeos\Shop\Controller\CheckoutController@updateAction | |
Post by aimeos » 22 May 2020, 17:05
You don't have your installation configured for multiple sites:
Your "routes" section in your ./config/shop.php file must at least look like:
'routes' => [
	'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']],
	'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']],
	'default' => ['prefix' => '{site}/shop', 'middleware' => ['web']]
